Recover MicroSDHC 32GB card
You need not worry. Few days back even i lost 16GB of data from SDHC card and effectively recovered all of them using Yodot Photo Recovery software. Just download its trial version and see if it helps you to regain your files. Click herefor more details
Hi…it is very anhnoying situation when you found that your microSDHC card has been corrupted or damaged. It can be corrupted due to different reasons but the simple to recover. You can perform different action to recover data on your microSDHC card. You can aslo use Card Data Recovery software in order to recover all the deleted or corrupted data from your microSDHC card. It is one of the effective way for recovery of corrupted data.
Recovering data from broken SD card requires lots of efforts since most data recovery software can’t recognize your card. You may try this card data recovery tool or take your card to a professional data recovery center for help. Good luck…
Hello! I am sorry to hear that you also lose your important memory card data. Honesty, about a month ago, I did get similar formatted memory card photo loss problems and found most of them were needed in next day. So, without knowing much about data recovery information, I also followed some data recovery suggestions online and took chances with some memory card format recovery software. Luckily, after trying several ones of them, I eventually had recovered many useful photos back.
So, if you also need such helps still, my experiences may also help you:
http://en.wikipedia.org/wiki/Photo_recovery
http://www.icare-recovery.com/howto/sd-card-photo-restore.html
Or http://www.piriform.com/recuva
Hope these articles can give you useful data recovery clues.
Well, this is not that hard to fix. Try Jihodoft File Recovery. It helped me to got all my data back. Good luck.
There are various reasons for Sandisk ultra 32gb micro SD not working. Some of the common causes are cracked or broken memory card, virus or malware infection, scratched card, inserting card improperly, incidence of unknown error, system shut down unknowingly, faulty connectors etc… Losing your valuable data from Sandisk ultra 32gb micro SD can be terribly unpleasant. Therefore, it is of utmost important to fix Sandisk ultra 32gb micro SD not working instantly. It’s very easy to do so using Photo Recovery Software.
Really losing precious pictures from sd card is worrying moment but going the this solution you can get them back:- http://www.recoverysoftw.com/
@sunshinegreen wrote:
You can try to recover deleted, formatted and lost files with this files recovery program. It’s good but not free.
Besides, you can also try freeware like Recuva and PhotoRec.
As I know some files recovery tool are better than Recuva and PhotoRec.
Both of these software are the same…
Recover all deleted photos from Windows and mac  http://www.stellardatarecovery.com/digital-media-recovery.php
hi reckor, I guess your MicroSDHC is corrupted. So you should check this guide -  Corrupted Memory Card Recovery. PhotoRec is good choice, also try TestDisk and DiskDigger for Windows. Good luck!
I have the same card 32 gig microsd and it has failed again. The reason I know is the phone will not load up apps. When I changed the card for a 2gig the phone reagined. I then tried this 32gig card in another phone and it would not work. the card was installed on a reader on my mac laptop and i can see 31.91 gb but am not sure what is on the card.
From the posts this seems to be the cards are not very reliable? this is the second time for me, once in a few months and now 11 months later. Sandisk 32gig micro sd ultra 80mbs hc 1 10 red and grey card used in a mobile phone. Android.
Vinnychoff
MobiKin SD Data Recovery will meet you needs. It will detect all the files in your SD card including the deleted and existing ones and then you can export the wanted files to computer. So the deleted files will be recovered to your computer. By the way, you should not play your mobile phone anymore when you found the data was lost. Because if you keeping playing your device there may be new files being added into your device and the new files may overwrite the deleted ones. Then you will be not able to recover the deleted ones.
There are a lot of data recovery software, you can also find free ones. I installed Disk Drill just to check it out. I can advise this article for making the right choice: https://www.cleverfiles.com/howto/best-free-data-recovery-software.html
Your SD card’s file system has turned into a RAW format. This means the file system structure (allocation table) is corrupted, but your photos and videos are highly likely still on the card. chkdsk (Check Disk) cannot repair the RAW format because its core principle is to maintain and fix logical errors within known file systems (such as FAT32, NTFS, or exFAT). Since RAW implies the file system is completely paralyzed or lost, running CHKDSK on a RAW drive is useless.
For now, do not write any new files to the SD card. If Windows prompts you to format it, click “Cancel”. You need to use specialized software to recover your files from the RAW SD card, and then format it. If you do not need the data inside, you can use the DiskPart command line to format it directly. You may also read this guide for other solutions: The Type of File System is RAW: Definition, Causes & Fixes
