Recover accidental formated drive
sir/ma’m ,
I have lost my all data due to accident format .is is 1TB HDD and now it seems empty …how can i get back my all data of my external HDD
please help me …
I am waiting your positive response
Thank you
2021-02-06T08:37:00Z2021-02-10T08:38:00Z
You can easily recover data from a fully formatted drive. As formatting, a drive does not wipe out the data permanently and there are traces of the data, left in the sectors of a drive and that’s from where a data recovery software fetches all your lost or deleted data.
There are many DIY data recovery software options that can help you recover your lost or deleted data. However, I will suggest you to try Stellar Data Recovery Professional Software because of its easy-to-use user interface and its reliability.
Further, I suggest you to check the below blog explaining the steps to recover data from a formatted drive:
Hope it helps!
I lost my data too, did you have any luck in restoring it?
In case you lost your data, then using a data recovery software is the only solution that can help you recover your data. As I mentioned above, I suggest you to try Stellar Data Recovery software that helps the user to recover their lost or deleted data from corrupted or accidentally formatted drive or even recovers lost partitions of the drive.
That’s a stressful situation affecting them, especially if your disk contained crucial information. I’m very sorry to learn that you formatted it by accident. The good news is that you have a chance to manually restore your data, provided you take immediate action and refrain from using the device anymore.
If you had File History or System Restore configured:
  1. Go to the folder where the files were originally stored (on another drive).
  2. Right-click > Restore previous versions.
  3. Select an available version and Restore.
If this method also does not work, then I will suggest you data recovery tool given by BLR Tools. This tool suggests my friend Mingyu… I use this solution to recover Windows data. I hope this company also provides a simple or direct solution to your situation. Try now..!! Or go to the official website.
The most important thing before recovering data from your hard drive is to stop writing new data to it, as doing so can overwrite your old files. Follow the steps below to recover your data:
  1. Stop using the external hard drive immediately.
    Do not copy or write anything to it—this includes downloading files, copying documents, reformatting, or repartitioning the drive.
  2. Use data recovery software to scan the external HDD and preview or recover any files found.
    (Note: To avoid data overwriting, do not install the recovery software on the external hard drive itself. Instead, download it to your computer. Likewise, save the recovered files to a safe location, such as your computer or another USB drive—not back to your 1TB external HDD.)
If you want, check out other tips in this how-to guide: Recover Lost Data & Repair Hard Drive Problems
