(I realize my first question has been asked before but I don’t think there was a clear cut consensus on any threads I looked at.)
I would like to plug the Fuze into a wall socket with an AC adapter for 8-10 hours a day. Will this cause the internal battery to overcharge or overheat?
After I’ve plugged the Fuze into a wall socket with an AC adapter and the battery has fully charged, if I wish to leave the Fuze plugged in and play music is the Fuze drawing power directly from AC or is it drawing power directly from the internal battery? In other words, is the internal battery supplying any power to the Fuze if I’m playing music while the Fuze is plugged into the wall?
Lastly, after several years of use (hypothetically) and the internal battery is no longer able to hold any charge (it has permanently died) will I still be able to plug the Fuze into a wall socket and be able to play it as long as it’s plugged in?
