How long does it take to charge the Clip with a wall charger? I’m wondering if I should get one, to preserve the display. How much do they cost? Is a wall charger generally recommended, rather than charging via USB?
I posted this back in early December, right after I got my Clip:
I bought this A/C adapter
http://store.bargaincell.com/B000I1XLG6/M/B000I1XLG6.htm
and this car cigarette lighter adapter
http://store.bargaincell.com/B000CRFDEO/M/B000CRFDEO.htm
for about $10 including shipping. So far they seem to be working great.
Both are still working great, though I don’t use the car charger too much.
I usually charge my Clip overnight (always using the wall charger), so I don’t know how long it takes to give a full charge. It should be about the same time as charging through the USB port on your computer.
I would definitely advise using a wall charger rather than charging thru the computer’s USB port. Not only do you preserve the display, but you can still use the Clip while it’s connected to the wall charger.
Thanx! The A/C adapter is now $1.50!! I’ll certainly think about it.
Just noticed buy.com has a Sansa travel kit on sale for $18 shipped. It includes AC and DC chargers plus cables and case. It’s item 35518.
Thanx, but I’d rather just get one simple AC adapter to plug into the wall & charge my Clip. As I noted above, I can get one for $1.50. Why pay $18 for a bunch of stuff I don’t need?
I don’t need the other cables, & I don’t use Google, so the $1.50 charger will do just fine. Miikerman, how long does it take to charge the Clip with the wall charger? Do you also recommend charging via A/C instead of the computer? Since I’m on my computer quite a bit, it’s pretty convenient for me. I just watch the clock, & unplug the Clip when it’s done charging…
Message Edited by Sasafrass452 on 01-22-2008 09:54 AM
Thanx, Miikerman. So, it takes about the same amount of time to charge via AC? That’s good to know… But I would also agree that usage of the display during USB charge does very little in terms of damage. Maybe I’ll save my money, & continue charging via USB…
Speaking of damage… Just out of curiosity, how hard of a hit can the Clip take before I should be concerned about internal damage? My cat thinks anything small is a toy, so if I happen to leave the Clip on the kitchen table, she’ll push it off to the floor which is very hard. Luckily, this hasn’t happened… yet.
Message Edited by Sasafrass452 on 01-22-2008 01:20 PM
Thanx for the input, I’ll be more watchful of where I put it from now on… I usually leave it on my dresser at night, but if my cat decides to jump up there & sees it, I’ll just put it in the drawer.
Message Edited by Sasafrass452 on 01-23-2008 04:03 PM
