If you get a Clip Zip and Rockbox it, then you could choose to have the display as large white letters on a black background using the runner theme. That is what I have. The display on the Clip zip is larger than the Clip+ display even though the players are very close in size. Rockbox is a free alternative operating system for the player that lets you choose from around 60 themes for how the display appears(what is displayed and how large each item is), and gives many more features and settings than the original firmware. The main drawback to Rockbox is that putting it on a player might make it permanently unable to play protected files. www.Rockbox.org
Some sort of self-gratification, I can only assume.
Rockbox isn’t the silver bullet, magic bean or be-all and end-all to everybody’s wants or needs in an mp3 player. Yes, it has its uses and benefits, but there’s really no need to include raving about it (now that you finally converted after how many years now?) in the majority of your posts.
Frankly, it gets a bit monotonous and irritating after a while.
