Is there a question here?
how to remove write protection from pen drive
Look at message #96 of this thread. Follow tips c, d & e.
where is the clipboard i copy and inser code i can’t understand so plz brifly desciption give me plz i have a broblem
After clicking on Reply on the top of the Reply window it is the 6th icon in from the left side. It looks like this:
The Solution is DO NOT BUY ANY PRODUCTS OF SANDISK… I have tried a lot but still my pendrive is write procted.
As has been posted here numerous times, if the drive is write protected RETURN IT. It is the only solution. Nothing else to try.
Return it to where you bought it or to SanDisk.
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
my pendrive sandisk of 8GB showing the msg of “write Protected” as in this case i am unabe to copy or format my pendrive so give me a solution for above mentioned problem and my pendrive model number is sandisk blade cruzer
Read the post immediately above yours. ![]()
upto here i did my pen drive but unable to format it please help… ![]()
Why do you want to format it?
1.Divice Menager sandisk cruzer USB media-unisal end 2. ran-regedit- edit- find-SanDisk-oll regkey -delete/3.restart PC/When you start the PC again put the usb problem is gone-format the USB and will no longer be a problem
SOLUTION
Disk 0
Disk 1,
Disk 2
SOLUTION
Disk 0
Disk 1,
Disk 2
same problem for mee toooo
that’s cool i find it usefull you saved my problem dude thanks again
@tapeworm wrote:
Why don’t you 2 call SanDisk Tech Support like I suggested (and provided a link to all SanDisk Tech Support contact numbers) 2 pages ago in this thread:
- The support reps are trained _ and _ paid to help people with problems such as you are experiencing.
- The contact numbers are toll-free.
- You could get help or get a warranty replacement right then and there while you are on the phone.
- You’d save yourselves the frustration and time (literally days) of posting back and forth here that may or may not fix your problem.
- TurboTax,Torrent,Gogo Anime
