Problem with My Passport Pro Thunderbolt
hello,
I do have a My Passport por for MAc (2TB, Thunderbolt). It’s almost new, 6 month max or so…
For an unkown reason, when I connect it it makes my mac crash.
When it does not, I tried to verify with the WD utility. Everything’s fine.
With Mac’s disk utilisy, it won’t complete the verification, prompts me to repair. Repair can’t complete and I get adviced to copy my data and reofrmat.
Problem is: can’t copy it the finder won’t finish it…
Can anyone help???
Thanks, JF
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
Support by Country
http://support.wdc.com/country/index.asp
Regards,
