Problem with my 16 gb memory card
i have a 16gb memory card
and i use it for my black berrry
jst a day ago idk wht happened my memory card stopped working
i keep getting an msg saying format ur memory card
i even did yes buh then it shows format was not able to be done
n then i tried pugging my phone in to my laptop to format my memory card
buh as sooon as i plug it in
a msg comes saying format d disk  u tried that i made a format but then it says windows was unable to format wht should i do
Contact SanDisk for a warranty replacement.
i didnt keep the bill
and i bought it 2 3 years ago
Probably won’t matter if you kept the reciept or not. Not many people do after that long a time. They can probably verify it’s a genuine SanDisk card by the serial number on it. Yes, you’ll probably need a magnifying glass unless you have very young eyes, but give them a call and see what they can do for you. :wink:
