Hello.
Because of the reasons, I have formatted the My Passport Ultra and used as blank drive.
have used like that for few moments.
Now I want to use it as exactly like when I purchased.
Is it possible to do that?
If I could, how do I do that?
Hello.
Hi vcblkm4dxgz8,
When you purchased the WD My Passport Ultra there was some WD Software which you have deleted while formatting the drive. However, you can download the WD Software from the link given below.
I know I can download the software and install, but what I asked as question was is it possible for me to restore or reset or make just like factory default just like purchased?
Hi vcblkm4dxgz8,
Yes, you can format the drive in NTFS file system to make it just like factory default, as it comes Pre-formatted in NTFS file system.
NOTE: Formatting is data destructive and cannot be undone.
I mean when I bought it and connected to computer, and prepare to use, disconnect, since then every time I connect drive to computer, it automatically makes unlock or something, to show up (if I set up password).
How do I make factory default that does this?
Cause as far as I know, when I purchase any other portable HDD, the hard drive has 2 parts: formatted part and another part that act like virtual drive like that has WD software installed?
