Is it possible to modify and add options to his mp3 ?
Hi @TocuouYTB ,
If you haven’t already, reaching out to the SD Technical Support team might be your best bet for troubleshooting. You can find resources similar to the DirectX SDK here that might also help with your project.
Tools like MP3Tag or iTunes can be really handy. For more advanced modifications, you might need a digital audio workstation like FL Studio or Ableton Live.
I did something similar when I was working on customizing a playlist for a road trip. I used some audio editing software to add metadata, adjust track order, and even clip some songs to better fit my needs.
It’s a bit like those floped games I tried out—some were underwhelming but tweaking and modifying them made them more enjoyable. Just get a good MP3 editor, and you should be able to adjust things like file tags and playback options to suit what you’re looking for.
with permisson or secrelty?
for local only
