Plug in external power supply, light comes on, then turns off
I have an older My Book model, 2TB I think. It turns on when I plug in the external power supply to a wall outlet. It has been working okay over the years, but tonight it presented a problem.
When I plug in the external power supply, a white light appears under the padlock icon on the face of the drive. I can feel and hear the plates inside whirring, but after a few seconds, it cuts off, and the machine is silent. I cannot access the hard drive at all.
What can I do at this point? Is is possible to recover the contents of this external hard drive?
Hi sporre02,
Hi
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
