hello, i bought a MP3 player 6 month ago and now i lost the CD program and i can’t download songs in it because we erased all programs on our computer and now i can’t download the program from the computer… please advise, how to download
thank you
thank you
you dont need any programs on the cd, you just plug it in and it works. only thing that was on the cd is the users manual, which can be downloaded from sandisk.com
I have looked all over SanDisk.com & have not been able to find any manuals. Any suggestions where to go on the site?
N
Here is a quickstart guide I found, http://www.sandisk.com/Retail/Default.aspx?CatID=1305
you should be able to watch the how to videos in my signature to figure out a lot of other things to.
you should be able to watch the how to videos in my signature to figure out a lot of other things to. You
Here is a link to a quick start guide i found; http://www.sandisk.com/Retail/Default.aspx?CatID=1305
You should watch the how to videos below, great for getting to know the product.
Make sure your player is detected by the PC. Connect it to the computer (the lcd should say connected with 3 letters on it) If it says MSC you should see a removable disk in my computer, if it says MTP you should see an “Audio Device” listed.
The link below will take you to Sansa’s page where you can either download a pdf version of the m200 User’s Guide or you can view it online by scrolling down and clicking on the individual chapter headings.
Since you asked the same question twice, I’ll answer it both places to be sure you see it.
