All the songs loaded on to my Sansa have been by wifi so I do not have a playlist for all these songs on my computer. Is there any way to generate a playlist based on what is on my connect so that when I lose wifi connectivity I can pick the songs up again from Rhapsody?
When you download songs onto your Connect, they are also automatically downloaded into Yahoo Music Jukebox when you log on. Your actual song library list is stored on Y! servers, so it should transfer when you migrate your account. If you want to create some playlists that will migrate too, log onto your account with YMJ, and let it download your library onto your computer. Then use YMJ to create your playlists, and they will migrate with your account.
