player turns off
I have a problem with my sansa clip and I would be glad if somebody can help me out. The problem is that since yesterday the player turns off for no reason (battery is full, I am not pressing th ‘off’ button). Right after that happpens I can turn it on again but sometimes not and then nothing happens. I cannot even finish one song anymore. I hope  somebody can tell me how to solve this problem. I’ll be glad to give more information if needed.
Thanks in advance,
Mieke
Probably a bad internal connections. If it’s under warranty contact Sansa, else there have been suggestions on opening the unit. I’m sure someone will tell you do the software things like reset, format and reload firmware. By all means do all of this and if it works I’d love to be wrong, but my guess is a bad connection.
If you get it fixed by doing the easy stuff, let us know for future reference.
