I can’t install the application on my Android smartphone, the phone memory seems insufficient. How to upgrade the phone memory capacity. Phone Memory Looks Full Problem
Happening with me too.
You still have choices.
- Insert an additional memory card(if your phone supports it).
In android deleting apps doens’t even help.
I deleted 20Apps from my phone and it’s still saying the same.
You should look into your “CAMERA” folder and “videos” folder about how much storage they are using.
You can use some file explorer like “filesGo” or “ESfilesExplorer” to analyze and find which folder is using more data.
After that, you would be able to clear your storage a bit.
Thanks
Thank you for sharing valuable information. Nice post. I enjoyed reading this post.
