Keeps showing a file called android when i delete it the file just pops back up over time there alot of files that go to other files that are empty at the end any idea what this is
I faced the same issue, but there in no problem in that android folder. It is some kind of back end file which contains apps related data.
The same file is on my phone and sd card its so annoying they filled up with 100s of empty ended files really need away of stopping them writing on my external memory tried finding some kind of app that would turn off permission but realised iv no idea what would happened by doing so
you don’t really need an another application to delete those files on your phone.
I found i couldnt delete them only way a app but now iv found if i change its name then all the hidden files show up so i can delete it
