pasward problem
i hav a sandisk 4gb memory card. but now the card doesnot accept the pasward. how can i unlock my micro sd memory card. pls hep me.
Some times it happens that you forgot the password of your memory card (MMC, micro SD) and you have lots of your important data in it. and You struggle to get back your password. Right? Today am going to show you how you can recover the lost password of your memory card with the help of nokia phone.
It is possible only if you have Nokia’s s60 phone (eg: 6600, 6610, N70,N73,E63,E71,N95)
The thing you got to do is download and install “Fileexplorer” software.
After installing follow the steps:
1. Open FExplorer and access the c: drive.
2. There u will find a file named ‘mmcstore’
3. Rename the file to: ‘mmcstore.txt’
4. The file will now open in notepad
5. U will get your password written in the notepad file
use the file explorer for the password restoring
](http://imagicon.info/cat/5-43/dontknow.gif[/IMG])
my sandisk memory card pasword by lost
Press and hold on a file and you will have options to pick the “hint question” that you defined when you set the password.
Its not tough to unlock card it is a simple procedure
So follow my steps:
Insert the card into computer and click on SD card and copy the MMSCTORE file and paste anywhere in computer that means you have edit access.
Right click on SD card and go to open with and open the file in  word and here your password in text form and now you can read your password and can unlock your card.
______________
[http://technical-support.igennie.co.uk]Technical](http://technical-support.igennie.co.uk]Technical)
[http://www.igennie.co.uk/hp-support.html]HP](http://www.igennie.co.uk/hp-support.html]HP)
So follow my steps:
______________
Not an issue, What you see in the file using MS Word is the password in encrypted form, NOT in the clear!
i forget my memory card password
Did you read any of the posts in this thread before you posted? In particular, this one?
Dear Sir/ Madam
**bleep** 8gb Memory SD Card passward forget.
Please advise.
Thanks
Nivas
@nivasnalawade wrote:
Dear Sir/ Madam
Please advise.
Did you read the post just above yours? Or any of the other posts in this thread?
:confounded: :angry:
Dear Sandisk team,
i am vardan so my sandisk memory card password missing so please help me.
how remove the password
please help me.
Thanks & Regards
 Vardan Zaware
   9820338224
Best Method:
1. Go to  file manager  of your mobile
2. In the Setting choose  system folders ,
_3. In the System folder, find a file named as  mmcstore _
_4. Send the file  on pc or laptop  with the help of data  cable or Bluetooth _
_5. Then,Open the file In  notepad _
_6. Once,file is open you will see the  password located in the file.  _
mobdro.io
1. Download  any  file Explorer  for your device to scan all file on your mobile
2. Start Explorer app & press zero(0).This will allow you to see system files
_3. the look for  MmcStore file ,which should be located in  /sys/data/mmcstore _
4. once you located above path then open it with any normal editor
_5. Now look in the third column,for the code like  !TMSD02G _
6. then  delete it.and you are reset you memory card password.
mobdro.io
