Memory card locked i forgot my password
Hi every one i need help regading… i face issue with my sandisk micro sd card. first of all i tell u i have sandisk ultra 8 gb microsd card which is red and grey colour… the issue is that prevoiusly i use this card on my nokia phone its work perfect after phone software update its shows my memory card locked with password. i didn’t remind my password. hmmm bow i wanna need how to remove this password.. i attempt several things i attach this card to my pc via card reader nd its not detectable nd this same thing was happen when insert in any mobile.. only work with my nokia phone and need password
Check this KB site. I hope this helps you out. http://kb.sandisk.com/app/answers/detail/a_id/7947/~/forgot-secureaccess-password
@rickyjm -
Why do you keep providing links for problems with flash drives, when the OP’s are having problems with memory cards? They are not the same thing. :confounded:
its solution for flash drives i got problem with sd card… plz tell me solution regarding how to unlock memory cards.
Memory cards by themselves do not have password protection capabilitites. It sounds like this is something your phone has injected, and therefore the phone is the only thing that can remove it.
how to remove password in sandisk using in my nokia c2-01 i forgot my password
Have you ever put your memory card into your computer, phone, or camera and then seen a message like “Enter Password to Access” or “Memory Card Locked”? It isn’t very pleasant, particularly if you have stored important documents, videos, or pictures. The information remains physically stored on the memory card even if you forget the password. Even from corrupted or locked cards, it can be safely extracted with the aid of a recovery tool. If you don’t believe in the free method, then users can try the BLR Tools Data Recovery Software. The process of formatting can decrease the likelihood of complete data recovery, so refrain from doing it immediately. If you are prepared to remove the contents, try recovery first and then reformat.
Nokia set the password so you will need to use that phone to access the data. If the phone cannot access the card you may need to format the card as fresh.
Don’t worry if your memory card is locked and you can’t remember the password; there are a few methods to get back in. Because some devices store the password internally, try unlocking it first using the same device (phone or camera) that was used to set it. In the event that this fails, connect the memory card to your computer and look for a hidden file called “mmcstore,” which is frequently present on older phones. The forgotten password might be visible if you open this file in a text editor.
If none of these work, you can use a computer or your device to format the memory card. It’s best to recover your files first because formatting removes all data.
Use a reliable data recovery software, such as BLR Memory Card Data Recovery Software, for this. Locked or formatted cards are swiftly scanned. Additionally, this program can recover files that have been erased or rendered inaccessible. With this tool, you can recover all of your documents, videos, and pictures from the memory card. Important data can be readily recovered even after a password loss thanks to its deep scanning capabilities and user-friendly interface.
