Passport essential problems galore
Hi
I have a wd passport and it froze on me last week and I had to use a data recovery system to retreive the data, which I did.
When I tried to enter the passport  again, it accepted the password ok  and then a window appeared and said I had to format the disc before anything else, however this kept failing. I checked the size of the passport and it shows 931GB but it wont take me onto the next stage which is to view the files etc.
It also shows a drive F on my computer which only appears when I plug the passport in and I can not access that either
What can I do?
use a formatting tool to erase and test the drive
you can use DLG
Hi
I have downloaded  the software and when I ran the setup , it shows a window to say that the process failed with an error code of 740?
Which tool did you use to recover data?
it was Stella Phoenix
