I got a problem with My Passport 1tb, it used to work fine now it stopped working.
I searched the net for solutions and nothing helped.
the symptoms are:
-I plug it to usb and win7 make a plug in sound.
-no auto run or any open option work.
-in my computer it appear as F: when i try to open the drive it takes few seconds and then i get the “F: is not accessible”
-WD My passport is shown in device manager-> disk drives BUT when i try to locate it in Disk Managment the whole application just FREEZE!
- when i unplug the drive from usb windows pop up message “you must format F: to use it” (or smth like that), and even when i tried to format it when it was plugged everyting freezed or “not responding”
I tryed it on other laptop and nothing. also tryed testdisk 6.12
Im sure the hardware is fine. the white light works and i can feel it working.
Probably happand after i unplugged it without safe remove or in the middle of data transfaring
I spent the whole day looking for solutions PLEASE HELP!
