help me out
my pc n lappy was not detecting my device i.e., my passport essential 500gb portable
plz plzz help me out
help me out
Hey there, I would recommend you to try one of the ports in the back if this is a desktop computer, test with different USB cables, different ports and as a last resort, try using the drive on a different computer, Check in Disk Management if the drive shows there, if it does show but not in My Computer, you might need to format the drive.
Did you do what Mr_MKS_Montana said?
There are only a few things that could cause your Passport to not be detected on your computer or laptop:
If you tried any of the above suggestions, and your drive still doesn’t show up in Computer or Disk Management, then you have to assume that your drive has failed. If your drive is still under warranty, then you can replace it with another through WD in your region.
