New to the Clip. 4gig, v2, current fw. I like the Sansa earbuds, good sound at half volume. Bought a cheap oth set and had to increase volume almost to full. And yes, driving larger speakers would make some difference. I don’t know the impedance of the earbuds, but the oth was 32 ohms.
My questions:
Anyone know the Clip specs, didn’t find anything on the web site?
My Sony full cover headphones take a lot higher volume setting (close to full) than my Sony buds (often the last click before total mute.) Works for me… if full volume isn’t enough for your setup, then you either need an external headphone amp or a different (most likely larger) player.
32 ohm drivers typically require more output to drive them properly. The Sansa is optimized for 16 ohm drivers, the most common impedance out there.
To enjoy 32 ohm or higher full-size drivers, you can use a headphone amplifier like the Fiio E3 or E5. I like these units, as they are inexpensive, and they’re teeny like the Clip!
