I am using a brand new Clip Zip bought on Amazon in the UK and trying to transfer music from a Windows 7 PC.
My problem is that only a small number of files have been transferred and it’s very intermittend. For example I had 3 folders each with about 10 tracks from an audio book. The first folder transferred without any problems. The second folder transferred only 2 tracks from the ten, then gave a message “You cannot copy (Tracknumber.mp3). You do not have permission to create this item”. It then just gives the option to skip the item or cancel the copying, and then gives the same message for each of the following tracks in the folder. These are just regular MP3 rips from an audio CD so no DRM issues.
When I tried to delete the partial folder so as to have another try I also got this message :-
“(Folder name) could not be deleted. The device has either stopped responding or has been disconnected”
So it seems as though (in non-tech language!) it’s like the device has fallen asleep
and lost connection with the main PC.
Is this a common problem and if so what is the fix?
Thanks
Colin
