Dell 8940 had problems but 2tb SSD works well. Bought a new Dell 8960. The SSD won’t initialize in the new PC. Virtual sez access is denied. I finally deleted the. SSD
It means the drive’s partition table or permissions got messed up, not that the SSD is dead.
Here’s 3 thing to consider:
Open Disk Management → if it shows as Unallocated, right-click and initialize it (pick GPT). Then create a new volume and format it.
If it still says “access denied,” use the command line tool DiskPart to clean it and create a new partition (takes a couple of minutes).
If Windows still struggles, update the SanDisk firmware using the WD Dashboard software, sometimes the 2TB models need that update to behave with newer Dell hardware.
To fix the issue, first check the BIOS to make sure the SSD is recognized, SATA is set to AHCI, and Intel RST is disabled if needed. Then, in Disk Management (run as Administrator), initialize the disk as GPT and create a new NTFS volume. If access is still denied, use Command Prompt as Administrator with Diskpart to select the disk and run the clean command, then reinitialize. Updating the SSD firmware may help, and any previous encryption or security flags may require a secure erase. Following these steps usually allows the SSD to work on the new PC.
Windows Disk Management often displays an “Access Denied” error due to permission issues; however, simple command-line tools can typically bypass these restrictions.
Enter “cmd” into the search box located in the bottom-left corner of your desktop.
Right-click on “Command Prompt” and select “Run as administrator.”
Enter the following commands sequentially (press Enter after each line has finished executing):
diskpart (Launches the disk management utility) list disk (Lists all disks currently connected to your computer; carefully note the disk numbers corresponding to your 2TB drive and your SSD—e.g., Disk 1 or Disk 2) select disk X (Replace “X” with the disk number corresponding to your 2TB drive—be absolutely certain you do not accidentally select your system drive!) clean (This command forcibly clears all partition tables and encryption information from the selected disk)
