I was just curious. How much space is there on the 2 GB Clip after formatting?
I have a 1 GB Clip and if we assume the device actually has 1 GB then it should have 1024 MB total when I follow the prompts to it after connecting it to my computer. Instead it says 965 MB. That’s a difference of 59 MB. Is it the same for the 2 GB?
I plan on returning mine and getting a 4 GB btw, cuz I can!
Hard drive manufactors had been sued cause they wrote 1Gig is actually equal to 1000Mbs. So not only does it take up space for the Fat Table, its also cause they have it at 1000MBs= to 1GB.
Just to clarify, because memory/storage manufacturers and operating systems define a gigabyte differently, the device appears to have less storage when formatted.
