I bought a Cruzer 32GB I will only hold 16GB
“I bought a Cruzer 32GB”
New or used?
How big are the files you’re loading to it?
Open My Computer, right click on the Sandisk drive and hit Properties. How m uch free space is listed?
Similar problem with 16gb usb flash drive. Packaging says 16gb, drive is only 2gb!! Purchased at best buy…
Wow! Seems like someone was pretty slick and slipped some fake SanDisk past BestBuy’s purchasing departments. For sure if it says SanDisk 32GB and only holds way less data, its fake. You can try testing to verify.
http://www.chinaelectronicsinsider.com/technical/how-test-fake-flash-memory
Wow! Seems like someone was pretty slick and slipped some spam or advertising for their own website into their signature! ![]()
Here’s your opportunity to remove it before it gets reported to the Admin and you get banned for violating Forum Rules. ![]()
Thanks for the heads up, fixed now! :smiley:
