In most cases if you see in the compatibility tool that you can use a slower card that you would actually like to buy, then its because the host device does not reach this high speed so it does not matter if you have a fast card if you cannot reach these speeds.
You can also contact the manufacturer of the host device to get clarity which features of the carsd you can use, U1 or U3, Class 10 and other specs.
