Dear Sir Or Madam
Have a nice day
I will explain my Problem in following points:-
Introduction:
- am using "WD My Passport Essential 500 GB " Since SEP-2010.
- i have password in “VCD”
- When i entering the password then “MyPassport Hard Drive” Will appear.
- i used my “WD Passport Essential” in my Laptop at Home & in my PC at Office.
Problem: - Before 2 Days i have connected “WD Passport Essential” in PC at office.
- i Unlocked, then When i Browsing my files the Device was Hang-up (FREEZE).
- i removed the USB cable from PC then i connected again.
- again i Unlocked, the am to able to open "WD My Passport: Drive…
- Drive is appear in my Computer, But the size is 0 (Zirro).
- When am trying to open the drive… Error message “No Writable SmartWare Partition Found”
- Also This message " The Disk in Drive “P” is Not Formated… Do You Want To Format Now ?"
- i have Very Important DATA saved in " WD Passport Essential " Drive. i don’t want to loss it.
- i want your Kind Support… How can i solve this Problem Without Losing my DATA ?1
Pleas Help My
Thanks & With My Best Regards
M. H. Kambal
