new 128gb extreme pro flash drive only reads 15gb
I formated my new 128gb extreme pro flashdrive in my mac to exfat and it says now it only has a 15gb capacity, how can i restore it to its original settings?
Hi @alexk
To resolve this issue, you may try the methods below:
Clear the Trash. If the available space on your flash drive doesn’t increase after deleting files, those files may still be stored in the drive’s own Trash folder. Empty the Trash completely, restart your Mac, and then check whether the free space is updated correctly.
Check and repair the flash drive. Run the First Aid feature in Disk Utility to scan for file system errors and fix them, then verify the available storage again.
( Related reading: macOS Shows Incorrect Free Space, Why & How to Fix It? )
