Hi, on my new sandisc there is no enough space, to backup my photos and i did not backup any thing
kindly help
Hi @OsamaJan
The following steps may help resolve the issue:
- Update the hard drive driver
Press the Start button, type Device Manager in the search box, and hit Enter.
Expand Disk drives, right-click on the hard drive with the incorrect capacity, and choose Update driver.
Select Search automatically for updated driver software.
- Reformat the USB drive
Please note that initializing or formatting an external SSD will erase all the data on it. Be sure to back up any important files before proceeding.
- Run the CHKDSK tool to check for errors
Open the Start menu, type cmd, right-click on Command Prompt, and select Run as administrator. Then run CHKDSK command to check for bad sectors or file system errors.
[ Follow the instructions in this related blog: (External) Hard Drive Not Showing Full Capacity? Try These Solutions! ]
