Hello im new here, I bought my passport 2TB 7 months back suddenly I not able to access the data’s inside, this problem occured because i fixed registry problems in my laptop via cc cleaner while the external hdd was still plugged in, suddenly when i plugged in again it should popup in my computer asI CD DRIVE (G:) WD UNLOCKER, but it just popup there as CD DRIVE. I read alot of forums online most of them wrote about disk management, device manager and command prompt, since my hdd is password protected i cant do anything, even I downloaded data recovery soft shows that no readable partition, please help me, I need al trhe data’s!!
Hi just a little note Google ccleaner destroyed my computer and you get 139,000 results even if only 1/4 of them is true it is a program to stay away from.
I’ve used Ccleaner for years and never had problems with it. I just updated it today. I’ve used it since Windows 98 up to Windows 7. I didn’t know thee was a Google version.
Hi there is not a Google version they have enough bad software all on there own hehe. I meant to run a search on Google using the search string “ccleaner destroyed my computer” and see the results. Myself I just delete temp files and clear the ie cache I don’t really need a program to do that.
Hi Heman91 I have one other question for you did you use the safely remove hardware function before you unplugged the drive. If you do not use that function it’s just a matter of time until you get a Partition Table Corruption rendering all data on that drive unreadable. It may not have been cc cleaner that caused the problem.
