I lost my Charger but my Sansa is an old Model will a charger from a newer model work on mine?Mine is the tallest one
You have a Sansa View.
I believe Sansa used the same 30-pin cable for E200, Fuze and View.
Here’s one that is supposed to be original SanDisk.
You can also search for Fuze or E200 Synch or Data cables online.
Hi. The link from amazon works. My brother in law just purchased it and it was compatible. ![]()
