Mypassport drive error in reading-Pls help
Hi All
I use to watch movie using my passport portable hard disk, but since yesterday it cannot work anymore.
I think is due to while I watch movie, then the compoter hang and then I restart the computer without unplug
my passport portable hard disk.Can someone help how to solve this problem ?
Now I can’t to access my passport portable hard disk anymore and I still can heard the “click,click” sound when
I plug the  my passwort to the computer.I try to change it to another computer also cannot work .This means that
my passport is breakdown and Can I still recover my data ?
Pls help
Thank you very much in advance
Hello alfredm88,
Check if the drive is showing under disk management if so test the drive using the WD DLG tool.
How to test a drive for problems using Data Lifeguard Diagnostics for Windows
