MyBook Studio II Mac 4TB - FW800 Daisey Chain Questions
I own 5 MyBook Studio II Mac 4TB.  I have intermittent problems when I use FW800 to daisey chain these drives to my 2010 Mac Pro, OS10,6,7. Can someone suggest a solution?
PeterHT, perhaps the following article might be of some help:
Answer ID 1490: WD FireWire enabled drives can be daisy-chained to a computer system.
The power strip is likely to be the source of the issue as the External Hard Disk Drives need an optimal power source in order to allow a desirable performance.
Regards,
I have 5 MyBook Studio II Mac 4TB - often one or more will not power up unless I disconnect it from a UPS or power strip, plug it into the wall, then replace it on the UPS.
Why? Can this be “fixed”?
