Mybook won't turn on. Please help!
Let me start off by thanking you. I appreciate any suggestions that is given.
I have had a WD 2tb mybook for around 2 years. I use it to house my iTunes library.  It’s been hooked up to a 24" iMac. I recently bought at new 27" iMac and during the data transfer removed all my external drives (thinking that I would transfer my library file from the old internal drive and then just plug in the actual media when i hooked up the external to the new computer). After the data transfer completed, I tried to hook the external in the new iMac and the drive won’t show any signs of life.
What are my options? I’m down to try just about anything, just want to be able to save my media.
Thanks again!
Is the drive connected to a power strip? If so, try to connect the unit directly to the power source. Also did you replace the interface cable? and as last trouble shoot technical advise, if you reconnect the drive to the other computer is recognize?
