I have same wite protct error. They say it is because of unsafe removal of USB stick.
There must be a way of removing write protection vua Sandisc tech support.
Can anybody help me?
Dave.
Dave.
way I did it was go to computer management and click on the usb drive and delete volume and it worked
Hi, I had the same issue with an ssd, according to sandisk support , write protected mode is done by the storage firmware when it traces problem in the storage.
To save the user data , the drive is going to a locked mode.
Since SanDisk does not provide for most storage e.g sdcard ssd a firnware update or reconfigure tool you can say r.i.p to the storage.
Other option is to backup and do llf.
Hope this helps.
its helpful and after long time i am able to use my 64gb Pandriveā¦thanks a lot Anish ![]()
This worked perfectly! Thanks Anish!
doesnāt work for my SanDisk ultra backup. READ ONLY
Return it to the seller or SanDisk. Replacements are free.
bro, i got fixed by this tool called Ratool.exe
Thanks for your sharing, but Ratool not working with my sandisk USB
Iāve tried every suggestion in this thread and everyone of them is unsuccessful because the drive is write protected.
Link is redirecting to another url
Worked perfectly on my Sandisk Ultra 32GB USB 3.1. Thanks !
So, in summary, to remove the write protect
These commands didnāt remove the Write Protect in my case so followed with
Thanks for the steps to fix the problem pacman11.
I would recommend formatting to exFAT rather than the disk NTFS format. Less writes to the drive.
Thanks for this feedback ed_p.
Youāre right, of course, but I couldnāt find the exFAT option. It must have been there somewhere but I was in a hurry and didnāt have time to search for it. So I went ahead with the NTFS option and when I got back from the coffee machine I had a USB stick which Windows 11 recognised and which I could quickly re-format to exFAT.
I donāt understand what you mean ⦠you couldnāt find the exFAT option ⦠arenāt you the one typing it in ? I did the exFAT option and ⦠I could have walked about the block several times ⦠itās not so quick LOL
same error
Check out this link: How to remove write protection from usb flash-drive? - #121 by luck
Returning it for a replacement failed!!
