My Sandisk Milpitas only shows 16K
My imac suddenly restarted and  i lost my sandisk , when i enter disk utility i only see capacity of 16 KB
This is terminal report :
 Device Identifier:        disk0
   Device Node:              /dev/disk0
   Whole:                    Yes
   Part of Whole:            disk0
   Device / Media Name:      Sandisk Milpitas SSD
   Volume Name:              Not applicable (no file system)
   Mounted:                  Not applicable (no file system)
   File System:              None
   Content (IOContent):      None
   OS Can Be Installed:      No
   Media Type:               Generic
   Protocol:                 SATA
   SMART Status:             Not Supported
   Disk Size:                16.4 KB (16384 Bytes) (exactly 32 512-Byte-Units)
   Device Block Size:        512 Bytes
   Read-Only Media:          No
   Read-Only Volume:         Not applicable (no file system)
   Device Location:          Internal
   Removable Media:          Fixed
   Solid State:              No
   Virtual:                  No
   OS 9 Drivers:             No
   Low Level Format:         Not supported
   Device Location:          “SSD”
Any comments welcome!
THanks in advance…
i have the same problem, and still 2 month no one can fix this problem neither Sandisk help fix this
16KB Milpitas issue seems to be a common yet random issue
Here is the same error after a few months BIOS sees it as Sandisk Milpitas, it is a Sandisk SSD Plus 480GB.
SSD shows 16kb! of storage and has this strange name “Sandisc Milpitas SSD”.
No SMART available.
How to recover data?
Linux testdisk sees C/H/S only 1 cylinder!
TIA
My SSD happened the same thing! !!!
someone succeeded in recovery?
Same problem and I see there are no answers to date about this issue and or how to recover data???
same problem with wd green 480gb … 16k 0mb unusable, any solution yet ?
does anyone hae a chance to recover data from 16kb multipas error
