I posted a query earlier and there seems to be others with the same issue.
Running Windows 7 Home Premium 32 bit fully updated
USB 3.0 card attached to PCIe x1 slot- drivers up to date
Drive works fine on USB 2.0 connection
Drive is visible in Explorer
USB 3.0 shuts down randomly and then reconnects. Asks me if I want to scan and fix errors and then shuts down and reconnects again. Will tell me I have to re-format the drive. If I try to transfer a file, it starts off at blazing speed for a few seconds then disconnects.
Could it be an issue drawing power from the MoBo? It has a 4 pin connector. There doesn’t seem to be a way in device manager to adjust any power settlings.
Suggestions appreciated. Thanks.
