Hi
I just recently bought a WD My Passport SE (1TB). Wanting to try out the USB3.0 connection, I immediately connected it to my USB3.0 port, updated the firmware and installe SmartWare.
I tried transfering files over in order to see how fast it is, but after a few seconds the drive disconnects for a fraction of a second and reconnects. This of course interrupts the transfer. I only seem to be able to transfer small-ish files.
I have tried uninstalling and re-installing the driver for both the USB3.0 driver and the hard drive. To no avail. I also tried performing a backup through SmartWare, and the same thing happens.
I connected it to a USB2 port, and it works without and problem.
Any recommendation as to what I should do?
PS: I am running Windows 7 64-bit, USB driver is Fresco Logic xHCI FL1000 series.
