I’m trying to transfer files to my WD 1 TB portable HDD ( passport) thru my notebook’s USB 3.0 . Unfortunately it keeps disconnecting and reconnects disrupting the file transfer.
I was reading the forum and after 2 weeks , I finally found a solution. The problem lies in the USB power setting in POwer Options within Windows.
The default is smart power saving for USB. This caused the Drive to get disconnected. You must access power management within control panel. Go to advance management and disable any smart power saving for the USB…
