Hi all. I have a My Passport Ultra 2TB which I use with my MacBook pro. For some reason it will now only list the contents alphabetically. It always used to list by last opened. I have tried to change this in the preferences box but to no avail. Anyone experienced a similar problem ? Any help would be appreciated.
Did you try to use this My Passport in another Mac?
This issue may be a system specific and try to check after manually customize the items to view in Finder Window.
Hi. No, it’s never been used with another Mac, only mine. Just doesn’t respond to reconfiguring the preferences.
