My Passport for Mac will not eject!
I just got two new WD Passports for Mac, 4TB. Both are plugged into my Macbook Pro. One supposedly ejected. One supposedly won’t because there are supposedly programs running. I cannot plug in a power supply because of the two Passports . Could anyone tell me how to get the passport to eject? And is this a problem?
Thanks.
Hi rosiebeeme,
Make sure there is no backup running as it won’t let you eject the drive safely. Also, you can try to eject the drive using WD Drive Utilities. Please refer to the link given below for more information.
https://support.wdc.com/knowledgebase/answer.aspx?ID=15058#wddu
