Hi I’ve been using my hard disk for the past six months.
But suddenly it stopped working.
When i connected it to my laptop the light blinks in the drive and the got detected but i dont see the memory usage. it just shows the a drive symbol. I attached the screen shot below Drive K is my hard disk
Also i tried connecting it to a ubuntu system it shows:
Error mounting - mount exited with exit code 13: ntfs_attr_pread_i:ntfs_pread
failed: I/O error
I also tried to do a chkdsk in windows but it gets hanged in the process… Please help with the issue
Thanks in advance
–Selvaraja M
Try testing the drive with our Data Lifeguard Diagnostics software or Windows chkdsk.
How to test a drive for problems using Data Lifeguard Diagnostics for Windows
http://wdc.custhelp.com/app/answers/detail/a_id/940
Hi John
Thanks for your reply.
I tried your suggestion. When I do a chkdsk the system gets hanged, and its not progressing.
I also tried Data Lifeguard Diagnostics software which couldn’t detect my drive, attaching the screen shot for the same
in the above screen shot k is my drive, which is not getting detected.
Please help on this.
awaiting your reply
Selvaraja M
