My passport essential 500gb is getting copied at a speed of 1MB/sec!
I bought my WD I year back. It worked properly for few months. After that it is getting copied at a speed of 1.2MB/sec!!!
I m completely fed up with this one.  Plz any one could help me with this…
  • Did you replace the USB cable?
  • Have you connect your drive to a different computer?
  • Have you connect your drive to a different USB port?
  • If you connect another storage device to your computer do you get the same transfer speed?
