Help needed with my passport essential
hi guys any help appreciated.
i have a wd passport essential 250gb thats about 16mths old.it has started giving me problems where it takes ages to simply copy files to and from.even a blank folder takes about 5 mins to transfer or delete.
i have ran chkdsk on the drive and it returns with 0 errors.i am able to reformat it no problem but the serious lag issues remain.i tried running a surface scan but cancelled it when it gave an aproximate end time a couple of weeks from now.it was scanning at a rate of 7mb per min.
it has 2 partitions both formatted to fat 32 split 50/50. i have only used one partition to store games and the other unused.it was working fine and the suddenly stopped.it still sounds ok and is in a position where it couldnt have been dropped or fallen.
is there any other tests i can perform?
would updating the drive with software help?
could it be that the drive is on the way out?.
the product no is WDBAAA2500ABK-00 if that helps.
thanks in advance.
scorzeze
It sounds like one of the partitions is corrupted
try backing up data and reformatting the entire drive
you can also write zeros or test the drive with Data Lifeguard or HD Tune
