My Passport 500 gb not recognized
I bought a 500gb usb 3.0 my passport external hd couple of weeks ago. It worked fine for the first week. But now I’m having a strange problem.
Windows shows my drive as RAW and says it needs to be formatted to continue. If the drive remains connected, a new dialog pops up every few minutes saying that
You need to format the disk in drive F: before you can use it" with a button to format. But when I click the button, after 5 minutes a dialog opens up saying
" Windows can’t  format F.
Check to see that the disk and drive are connected properly, make sure that the disk is not read-only and then try again. For more information, search Help for read-only files and how to change them."
I’ve faced this problem before with my Toshiba drive and I used to run a data recovery software to recover data and then format the drive. I tried doing the same with my new WD one. But none of the data recovery softwares ( I tried Easus and mini tools one ) recognise the drive.
I tried calling all the nos. listed for western digital support in India, but none of the numbers are correct. I also posted the same question in their support page but received no reply.
I would like to recover my data somewhow, if possible. But if it is not, I would like to format the hard drive and move on.
Please help. There was no password set on my drive, if it helps in any way.
I just posted an answer to this here http://community.wdc.com/t5/My-Book-for-PC/WD-My-Book-Home-Edition-not-functioning/td-p/218268
Joe
Nope. You provided the link to the minitools recovery software. I already tried that one and the Easus one too. Both do not detect the drive when plugged in.
I am facing the same issue. Were you able to recover your data or to format the disk?
Thanks.
Sorry try this link http://windows7forums.com/windows-7-hardware/52429-hard-drive-unrecognizable-file-system.html
Joe
