My hard drive isn't working
I had my other computer with the hard drive in it but when I was about to take it out it said do you want to wipe the data off this hard drive and my finger sliped and i pressed yes and now all the data i needed for my new computer was wiped and i don’t have the data from the hard drive to download the app so it can work. now it doesn’t work. does anyone know how to get data back?
Hi meme123,
You can try contacting Data recovery to get data recover from the drive. However, if you want to get applications or software which provided with the WD drive, you may refer WD Support site to download.
