excuse sorry to disturb u dear actually i lost my (my book) power adaptor kindly tell me what is the specification of power adaptor or my book 1Tb external power…?
To review the problem of not being able access WD external MY Book Essentials on a PC with WIN 7 pro.
I have tried this HD on two older PCs with XP OS and both have worked just fine.
I also tried another external drive a Kaser Storage Vault(which has a 250GB WD Drive inside) and it presented the same identical problem of not being able to access the drive through Win7 Explorer .
There was no problem seeing both drives in Disk Management. It does appear to be a problem associated
with Win 7 Explorer. Formating does not seem to be a solution as all data is wiped out. ( I have tried this
suggestion on MY Book drive to find it does not solve the problem. I can still access thru the XP PCs but not Win 7 PCs
There has to be some data on these disks that is not being recognized by win7 so it can be accessed thru explorer.
This is just a users forum not WD support. If the drive works on XP but not in Win 7 I’d look there for a problem. In Windows 7 does Disk Management show that the drive has a letter and is online? Does it say anything there about the drive indicating a problem like raw? Did you check the sharing/permissions in Windows 7? They can cause a lot of trouble. The sharing is a pain to work through I’m a single user so I allowed full permission for Everybody so I could access it from my other PCs that are networked.
