I am not able to access my WD Mybook essential. I am on WIndows 10 used to work. But in the last 2-3 days
When I connect I see MYbook in the USB icon
Says not initialized in disk management
Ub=nable to see the drive in MyPC
Did the following
thanks for the help
Welcome to the WD Community.
Are you able to test the drive on a different system?
Please note that not getting enough power could be an issue. Make sure that the power cable is directly connected to the wall outlet.
wnei
3
I have the same problem… and no solution…
See
Its the same problem too… and WD says that it possible to give a solution… but how?
Please… we need a solution
