Ichigo wrote:
It is weird then that the Passport is not showing up on the disk management window. You could try using a data recovery program to recover your files, with the help of Google you should be able to find several options.
warranty is showing upto next mounth
My 1Tb passport is not showing in PC & Laptop led is glowing and some sound is coming like… tik…tik.
Pls help
